That's an interesting point. In recent times, I've been going up a learning curve with the grit blaster I bought about a year ago. Now, many would say that a blasted surface is the best surface for paint. I've been using re-cycled glass as the media, and maybe getting the gun too close to the work piece. When I spray painted some blasted parts, I'd get these odd spots where the paint did not take and I realised the spots were places where the glass had embedded in the metal. So I decided to eliminate the problem by using a wire brush on a grinder to remove any embedded bits after the blasting. The extent to which the high-speed brush polished the blasted surface was quite a surprise - very visible!id go with a flap disc of a suitable grade , wire wheels tend to polish the surface and your paint might not stick that great vs a sanded finish
Never thought, or heard of that.I sharpen my wire brushes on the grinder to perk up the tips of the wires. Otherwise they just polish.
I haven't a clue what the rpm is but what can be wrong with it? Can it be too fast?Wire cup brush either on an angle grinder (check the rpm though) or get one with a spindle and use it in a drill.
I've normally 40 grit for welds. What grit is best for cleaning rust?id go with a flap disc of a suitable grade , wire wheels tend to polish the surface and your paint might not stick that great vs a sanded finish
Which got me wondering, is there a commercially available reversible angle grinder with all the perils that might ensue.if you're using a wire brush in a drill, change the direction of rotation, that keeps the wires sharp
they dont last long mindBought one of these plastic wheels in lidl for giggles. Works well for removing paint and rust.
True.they dont last long mind![]()
is that good enough? if so i am off out to get some for my bumperblast with kiln dried sand![]()
