I know, that the problem of the blown capacitors was caused by not using the device for a long time.From the way that the problem on your machine occurred after a period of non-use, it sounds like the insulating aluminium oxide film in the electrolytic capacitors deteriorated, causing a short-circuit.
I think that happened within one minute after switching on the machine. I haven't tried to weld, but I didn't switched off the device immediately (because at first I wasn't sure, which device caused the bang). I switched off the device after about 2 minutes. My next mistake was turning it back on again after a short while (tto see if it was still working) - it powered on normally but a few minutes later it got dark (this was propably the moment, when the winding of the transformer got damaged due to the short circuit of the capacitor).How soon after you switched your machine on did the fault occur, and had you already tried to weld by then?
I think, that the label on the transformer (14:38:38:14) describes the amount of windings or the ratio of the coils. In that case, there seem to be 4 coils included in this transformer. It might be somthing like this https://pdf.directindustry.com/pdf/...co-ltd/flyback-transformer/224418-928933.html but with only 8 pins.How many windings are on the transformer?
No - not yet. But you can see that the insulation film is burnt and discolored (that's why I think it's damaged). I will unsolder it maybe this weekend.Have you removed it from the board and confirmed that the windings are open-circuit?
I've already looked at all of these entries - there is no transformer with this ratio available.The Chinese website Alibaba lists many electronic components and complete PCBs used in the "generic" inverter welders, but as you said, it is hard to track down the exact part:
This would be the last option - since there are two coils on each side of the core and these are also insolated with a foil, it wouldn't be that easy. The windings are very thin (not thick as you mentioned) - the affected transformer is on the PCB for the internal power supply (not on the high power side).I think there will not be much wire on this transformer, and the windings will be quite thick. You may be able to dismantle it, count the turns, and rewind it yourself, or find a local transformer/motor rewinding company to do this. To resist the skin effect at the high frequencies used in inverters, the wire used may be multi-strand "Litz" wire.
I guess this board may be supplied by AC mains, or powered by the main DC bus after the input rectifiers ( i.e. it is a DC-DC converter ). Either way, if you know the output voltage(s), maybe you could replace it with a general-purpose power supply.the affected transformer is on the PCB for the internal power supply (not on the high power side)
Exactly you pay for 2 machines when u buy it...I'm inclined to agree with Fred Moore on this issue - my gut feeling is that most, if not all, of these 'sub-premium' Inverters share most, if not all, of the same stuff - from the same production line(s) - inside, or as near-as-dammit to not really matter.
Look at the controls available on that Thermal Arc above - pretty much the same as that Fantasy (oh what a dumb name...) and many other digital control panel welding machines I've looked at all look the same except the layout of the controlling 'buttons' and graphics are different. I very much doubt there is 1,000 Chinese factories all producing this stuff in the volumes required to allow western sellers the buy-price headroom in order for them to offer two year warranties on the stuff. imo this stuff has to be really MASS produced to keep unit costs low enough to make the business model work.
I notice on this site that there is much banging on about R-Tech (and I ain't knocking em) - but where are the internals for their machines made? My guess is that if it was in the UK the item would cost a couple of grand more instead. There are enough people saying they've had to send their R-Tech back as it had failed (and, yes, great customer service etc, replaced it) - but that's hardly 'bullet proof' reliability is it? Their business model has enough profit margin built into the cost of the units to allow it to work. Therefore... my GUESS is that we can probably obtain much cheaper machines of the same effective component quality...
Or summat like that anyway...
OK... I'm ready for the![]()
From my understanding it is a case of quality control, chinese companies will build anything to a price, they are no doubt made in the same factories by the same people, but if a customer specifies a certain level of quality and pay the extra I think they get a better machine, I think it is probably the same the world over.
I bought a cut40 years ago, the guy explained that he opened up every machine and inspected them, he said a lot of the time it is silly little things that let the machines down, so if checked and sorted before use then they last well. MY cut40 is still working well after nearly 4 years, even with me oerating it....
I dont have a problem with chinese built stuff, it is who/where you buy it from that is key, a good reputation for customer service and a good warranty from a company that will still be around in a years time. I would pay the extra for a uk supplied machine simply for the back up and peace of mind.
