No good I'm afraid. I don't get control over the fastener.Use Taptite screws instead (if they exist that small)
Ok, so ive approved the laser cutting at 2.3mm dia for the pilots
Roll taps a.k.a thread forming taps are critical on hole size but you get a nice strong thread with them. If your taps are tearing out the threads then I suggest using a better lube.
Why not get the laser company to bash out a test plate in your desired material with a couple of hundred holes say 5 lots of 40 in steps of 0.1mm? That way you can fine-tune your tapping setup for the mass production.
I don’t think the run out would be a problem, the reversing heads usually have collets with rubber between the jaws that allow a bit of flex.Ok, so ive approved the laser cutting at 2.3mm dia for the pilots, and just ordered one of these -
M2.5 x 0.45 FLUTELESS THREAD FORMING ROLL TAP OSG RH4-P | eBay
Find many great new & used options and get the best deals for M2.5 x 0.45 FLUTELESS THREAD FORMING ROLL TAP OSG RH4-P at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
which i think is some Japanese company's product.
Ill have a go on the first 5 units (170 holes) with what i have here (drill press, battery drill, etc) and see how i go.
If the job is a go-er, then ill order one of those things for the drill press.
One concern - my drill press has a little run-out. Ive never measured it, but i dont clamp parts when drilling, as there is a little wobble. Obviously more apparent with long drills.
I assume, if people are talking about doing these with hand drills, that getting one of those reversing chucks wont be a problem with some minor run out? Again, its not like ill be clamping the part anyway, as ill be working at speed.
Thanks to all.
www.myford.co.uk
Roll taps need precise holes, without any hardening or crap….
If laser cutting the holes reduces the effort a lot, then a spiral point tap will be most forgiving, but you will need the smaller 2.05mm holes.
My choice would be get the holes marked. Drill them with a carbide stub drill in drill press just before tapping with cordless.
I use 2.1mm carbide drills for most small holes including with cordless. The reduced flex keeps it right on the centre punch instead of wondering about like a normal hss will.
