Here are a couple of pics for you Mr Flatmajor,The ackro's I used have a 3mm wall section, not 6mm as mentioned before, the bumper is bolted to the chassis using the original bolts and the original holes, I made the plates to bolt it on with out of 3mm chequer plate ( because I had it)
I cut blanks for the ends with a holesaw filled the hole in the center with weld as I welded them on'
The recovery points are bolted on and welded.
Steering gaurd next thing to make
two bits of scaffold tube bent by grinding nearly through, bending and welding back together and a couple of bits of plate i had kicking around.
Your one rules, i dont know whether it cos you painted it yellow or what!!
