InkscapeYou need to scan it Into something ink-something then create a dxf file using another bit of software.
Me thinks.
Iv made a cardboard template for a car part is there a way to convert it for plasma laser water jet cutting ? or can someone do it for me ?
Its just under 430 long and 130 wide so longer than my A4 scanner.
Thanks
Steve
Not sure. I know it exists on my table but have never used it. Maybe @Fraserb or @doubleboost have got good experience with it. Failing that Rob Rosetti at Xtreme is the man.Can you do a dimensioned sketch?
I did think about buying one of them but not sure.Not sure. I know it exists on my table but have never used it. Maybe @Fraserb or @doubleboost have got good experience with it. Failing that Rob Rosetti at Xtreme is the man.
no rushI did think about buying one of them but not sure.
Inkscape will do it. If you go to your local library they will likely have a a3 scanner. I would draw an accurate box of known dimensions- 100x100 to help with scaling the rest of it when it’s scanned.
If you manage to get it scanned with a dimension as above then I may be able to do something with it. How soon do you need it?
Practise is the answer for inkscape, I can do things in a fraction of the time now compared to last year.
As I'm used to AutoCAD I downloaded this random photo off the web yesterday. I started tracing the roof lines, the individual window panes, the doorways and lintels then the gutter down pipes etc trying to draw from how you do your patio heaters.
Then I started on the bench and got distracted...
