pedrobedro
Man at Matalan
- CX near Chesterfield
In that case I have 365 girlfriends..............
Potentially ?
Rising sun immediately made me think of the Japanese flag.
Potentially ?
Did you "just" process the jpeg in Inkscape or did you alter it?
I'm guessing it's a raster to vector type thing it does.
Been playing here ourselves with Inkscape.
Thinking it might be better if I just redraw the whole thing in AutoCAD so I can print and tout it around local. I'm thinking to just scale the photo.
I just re drew it over the top of the photo, I can send you the svg file if you want.
Jobs yours as i have zero artistic skillsI could provide one judging by yesterday's attempts on the metal folder, looked like a welder welding who isn't one and can't!
im Not sure my friend. I only have a cut 50?I could do something when I get a chance, do you want it drawn so it's cuttable on a plasma?
Heres an idea. If you can work your magic we can all have a go at making one and post up our efforts ?
Yes thanks. That will be a great additionWhat I'll do is draw it up so it's suitable for the cnc plasma, people can then do as they please with it, are you wanting "The Welders Arms" added into it.
If you get the design from Fraser and print it. Stick it onto a thin bit of ply and cut round the lines allowing a suitable offset (usually about 6mm) you can then run your cut 50 torch round it. Just a thought If you wanted to cut it yourself.im Not sure my friend. I only have a cut 50?
Good idea, and yes i will have a go at making oneIf you get the design from Fraser and print it. Stick it onto a thin bit of ply and cut round the lines allowing a suitable offset (usually about 6mm) you can then run your cut 50 torch round it. Just a thought If you wanted to cut it yourself.
Thats simply quite awesome. I was going to message here and enquire if my suggested picture was too complicated, but im blown away with what you have done
Im definitely going to have a go at making the a sign. Who else is going to have a go ?
Now for the technical bit, are the black lines on the image where i would cut with the plasma ?
Make the competition a bit harder...a hand tools only rulewe can all have a go at making one and post up our efforts ?
Perhaps there could be a different category to any competition. ?Make the competition a bit harder...a hand tools only rule![]()
