8ob
- Nescient in the vale
Very nice indeed! That's a MT3 machine is it not?Acquired another dent in my wallet. It was a nice surprise to find out I won the bid when we arrived home from a motorcycle club function last night. I've been watching this "Fobco 10 Eight" drill press with anticipation, as it's rare to see one that looks to have had little use and appears to be in unabused condition. I previously contacted the owner and found that its at a residence rather than at an industrial site, so that added weight in influencing me to take a punt. Looks like a road trip is in order, I like a road trip.
Here's a couple of screen shot photos.
Apparently so, MT3 was listed in the description. It was one of the main reasons I was interested. I still have quite a few MT3 drill bits and a couple of Jacobs super chucks from my 14" Clausing lathe, which I sold overseas.Very nice indeed! That's a MT3 machine is it not?
I messaged RDG and they sent out another. This one even shorter, but is fully ground all over and much better quality, so Im happy with that.Test fit.. and roughtly aligned in photo for where they sit in the spindle. The mt3 is not the correct length. I can imagine this marking the spindle and rasing a burr where the mt3 ends too short.View attachment 303172
Should I send this back?
Glad it wasn't on yer biffin!In answer to the question of where on your arris was the boil. The boil was located at the top of my back between the shoulder blades, so nowhere remotely embarrassing chaps.![]()
Was that on eBay?Acquired another dent in my wallet. It was a nice surprise to find out I won the bid when we arrived home from a motorcycle club function last night. I've been watching this "Fobco 10 Eight" drill press with anticipation, as it's rare to see one that looks to have had little use and appears to be in unabused condition. I previously contacted the owner and found that its at a residence rather than at an industrial site, so that added weight in influencing me to take a punt. Looks like a road trip is in order, I like a road trip.
View attachment 304138 View attachment 304139
Yes, it was on ebay. Its the largest version of the Fobco drill presses. The " 7 Eight " models usually have a 3/4 HP motor with an MT2 tapered spindle, and the " 10 Eight " model spec is for a 1 1/2 HP motor and MT3 spindle. There is more information about them and other machines on the www.lathes.co.uk website. Scroll down towards the bottom of the title page on the right hand side.Was that on eBay?
Lovely looking machine
Is the only difference between the 7 and 10 the spindle?
I have a 7 Eight, there were spindles available for the 10 Eight on lathes.co.uk but that was years agoYes, it was on ebay. Its the largest version of the Fobco drill presses. The " 7 Eight " models usually have a 3/4 HP motor with an MT2 tapered spindle, and the " 10 Eight " model spec is for a 1 1/2 HP motor and MT3 spindle. There is more information about them and other machines on the www.lathes.co.uk website. Scroll down towards the bottom of the title page on the right hand side.
I rescued from a scrapped reeler turnover shaft at work, a 5 ft length of 5" round bar, not sure what grade but something decenteither En16 or En24. Good for making pins, anyway...
or the amount of effert you expend to get itEasy to lift from a skip into your boot with the pikey strength you gain when somethings free![]()
I’m after a 200mm length of 5” dia bar if you wanted some help shifting itI rescued from a scrapped reeler turnover shaft at work, a 5 ft length of 5" round bar, not sure what grade but something decenteither En16 or En24. Good for making pins, anyway...
need a few tooth pics
Actually I abused my position and got the shift engineer to put it in the van and run it along to my own workshopEasy to lift from a skip into your boot with the pikey strength you gain when somethings free![]()
Think I'd have made precision shaped long inner tubes for the cut tubes with a few drilled side holes where I could add weld then tigged it up all round and ground down the differences . Back in 1967 my future Bro in law Ged repaired my French touring bicycle that some ****** who decided to cut off the cycle lock &chain , then play silly B's with it . They'd broken the front wheel & snapped the front forks about 8 inches up from the spindle doing just that.Just for a change i visited the yacht club scrap skip, many of you will have noticed that over the last few years i have done rather well acquiring stuff out of this skip.
Well today it was a case of Today i didnt acquire! Sticking out of the skip is the remains of a Pashley Courier tradesmens bicycle, it had been in extremely good condition & fully complete. Unfortunately some complete klutz has chopped it up with an angle grinder forks, frame handlebars all fubared.
They are going for well over £300 on eblag. I could have sheet & stamped in it!
Ah well better luck next time!
I purchased four 9 inchers ( £ 36 for 4 lockable swivels ) like, that welded up a foot plate & spigot then bolted the wheels to the spigot. Slipping them in the base legs of my 10 foot high X 2" galv tower scaffold & securing them in place with a welded nut & side bolt and hey presto the heavy scaff tower is now easily portable ., It's good for washing the caravan as I've a bust back & arm , cleaning the bungalows gutters & the solar PV panels l.Today I acquired some gurt castors to go on my engine test bench, the brake locks the wheel and the castor
Here is where I got my braked locking castors six years ago . If you can't find what you want ask them for help .I hate castors that don't lock rotationally with the wheel brake. Stuff still moves with the brake on. Where did you get them from?
