The really great thing about our colonial friends, is they are surprised by the British knowing about the Imperial measuring system......
I like it because it is so simple and fascinating the way it works.That looks an interesting gate latch...I've never seen one like that before.
Saw it on facebook in a video, the welding was not good but the idea is goodI like it because it is so simple and fascinating the way it works.
Somone will say that, and then put fingers in it, open gate and chop then off. If its possible, somone will try itThat looks an interesting gate latch...I've never seen one like that before.
It does look like you could trap fingers but in practice fingers don't go into the bitey bits. Engaging the latch is hands free and disengagement is simply a matter of pushing the ring up a little, just past the point where it is locked, which you can do with an open palm. It might be possible to trap fingers but you would have to be pretty unconscious to do so and anyone doing anything that unconsciously could do with a lesson in paying attention!I like the gate latch, but..
If the hoop could have plenty of clearance with the side plates that shouldnt be possible. Might hurt or bend fingers, but they'd stay attached.
You'll never fix it in the rain, check the évacuation holes aren't blocked.Damn.
Today big boss called.
Massive leaks into passenger cabin.
Try to fix this fuxxing leaking window with some tile adjuster.
Now waiting for further advice from my wife.
hope that it is sealed now.
Otherwise I going to seal this VW extra feature forever.
SWMBO...No drains here.
It is obviously a common problem.
Seals getting weak and will leak.
But anyway these van is absolutely reliable to getting us around.
My wife will not have anything else.
That’s what she said ;-)
I liké, never heard of that.Stix-All sealant / adhesive / filler WILL stick in the wet if you have to. It's a hybrid polymer from Ever-Build and available in Black, Crystal Clear, and White.
Personally I've only used the black but it's pretty amazing stuff.
I'd run a bead of 6013, at a million amps, that fuses glass to steel / fiberglass, with a flicking movement, keeping the pool 'moist' etc, etc, etc.....Naaa.
This is a welding community.
So try to get some glass rods.
If it fails I have a chance with duct tape.
It will do the job.
sure….
Last chance to avoid is to describe it as a feature, not as a buck.
But it could getting complicated.
