angellonewolf
- bristol england
if i open the tap slow the water just keeps coming only a mm or 2 in the bottem of a thimble so not lots now once all the pressure is out i fill again and then there is again a little more water aagin just the 1or 2 mm in the bottem of a thimbleYou can only drain what is in there at the time you open the tap. If you have some pressure in it then close the tap as soon as the water stops coming out
as @Munkul said, every time you run it the compressor pump heats up and as the air goes in to the tank it cools on the inner surface and water condenses out which is why you have the drain valve
If they are used a lot and people don't empty them then it can collect until you can hear the water slopping about inside when you rock them
Opening the end plug just to drain it is overkill
opening the end cap yes extreme but if its just this time before i start using it full time i just want to start as new with no water in there
yes id guess its the warm air compressed air that causes the waterI've got one that's the same I think. You can get 2 types - one "oil free" and one that takes oil (I had the latter as I felt it'd be better).
Yep the trip is there to protect the motor from being cooked - so with the shaft being seized the inrush of current to try to start it would have popped the trip in no time. Now its freed off, if the bearings are ok you shouldn't have any more probs.
My guess is with the small 50L receiver and the compressor getting pretty warm (and needing to come on more often) is what creates the amount of condensation. I'd have got a larger one but I don't have the space.
The valves on these though are pretty small bore and a bit Mickey Mouse. I bought a couple of better shut-off valves and put those on instead of the originals
id like to chage a bit on there to better like the valves but untill its been working for a month or 2 im just going to see if it runs ok before throwing time and money at it
as before ive got a 1 with a bigger tank but its to big thsi one in the pic is about 1/3 to a 1/2 smaller than the bigger one i think
the bigger one is a air master 8/50 where as this is 8/44 i dont know the differance but im assuming not going to be big differance but that little smaller fits in the space neat where as the big one would stick out that much more
after a month it drops enough and cuts in . i wouldn't recommend leaving turned on because a hose bust and it ran on and burnt the motor out
