Brad93
- Essex, United Kingdom
IndeedA lighter wallet?
It's blue but the similarity ends there.Some say Hamerite smooth blue is close.
Best colur match was done Phill The paint, when he matched a sample on a vice.Indeed
Have you got a RAL number or something?It's Paragon Record Blue
See you made tool of the week on Homemade tools.net?A couple of knurled knobs:
They allow me to fit the table (with some washers to take the place of the cover that will eventually be between the aluminium body and the table bracket):
I need to reduce the depth of the table, but that was expected. I'd erred on the side of too big on the premise it's a lot easier to make it smaller than bigger. At the moment it clears the disc, but only just. I'd like there to be enough room between the disc and the table to allow me to change discs (typically to a finer grit) without moving the table. It should be a very quick job at the weekend to skim a millimetre or two off the side closest to the disc.
Rovers,with high comp pistons?Adapted more than made, repurposed a couple of discarded/dumped shopping trolleys. They make good trolleys for storing/moving v8 engines
View attachment 299760View attachment 299761
Or get a CNC Plasma, I know a guy who has a machine torch for oneWe finished this pallet of plates today. Glad that's done with, in hindsight it would have made more sense to get a 10mm plate and get someone to cut it all... But oh well.
Windsor’s or Cleveland’s ?Small block Fords![]()
Got a couple of 351 Windsor’s here, both Mexican with the GT40 P heads.There are a few of them, one is a Mexican 302 W ( supposedly a thicker/stronger block), a couple of stock 302W`s, a Boss 302 which is a 4 bolt main Windsor block with Cleveland heads ( rare piece) and there is a Nascar Winsor engine.
Bob
