daedalusminos
 - Norwich
I like that. I like that a lotRe-made some very worn throttle rods on a '56 Vauxhall Velox. Had to make a simple press brake to bend the 7/32 and 1/4" mild steel rods. I replaced some of the ends with ball joints and turned bushes where the receiving part were worn (saves welding and redrilling). Finished in cold black oxide.
View attachment 297258View attachment 297259View attachment 297260
If you've got all day and are sitting comfortably then I'll begin........
What do you mean ' listen with' I wrote it. Well SHMBO thinks I did and still do.I didn't realise you were old enough to remember "Listen with Mother".![]()
but thats another story.. Along the river bank.'Twas a radio programme [before telly], and the presenter used to say [before launching into a story] "Are you sitting comfortably? Then I'll begin...."![]()
Muffin the mule.but thats another story.. Along the river bank.
How did you do that? Not the work, the changing photos, first time I've seen that.
Don’t forget Larry the lamb & Toytown.Muffin the mule.
Bloody annoying, isn't it?How did you do that? Not the work, the changing photos, first time I've seen that.
No, I like.Bloody annoying, isn't it?
Nice tig work on the hose flange adaptor, stop putting us to shame with your productivity...Made a sleeve to go between the rod end of the steering ram and the steering rod on the Cat I am currently fitting out.
Couple of spacers for rollers.
Cut a flange and welded it to a hose adapter.
Welded the hinge to the lifting handrail.
Drilled a hole and milled a slot so I could fit the plunger at the other end of the rail.
Turned the face and taper on some 17" hauler plates.
Started on a stainless knife for the hauler. Milled the profile out of a chunk of 30mm thick stainless.
Flipped it over and milled off the extra 5mm
Ready for milling the tapers to both sides but that will be in the future as had enough for the day.
Actually did a few other bits but no pics , would have done more but was inundated with fishermen asking when I will be able to do other jobs for them. PITA you tell them you are busy but they want to stand an yap for an hourNice tig work on the hose flange adaptor, stop putting us to shame with your productivity...
 after a while I just went and got on and left them yapping and eventually they got the message
