Agroshield
The woodwork shop had a bigger version of that at school.
The woodwork shop had a bigger version of that at school. Disc was around 40cm and set up like a (old) record player. Post off one corner held the tool clamp which swung to even the wear. Ace for plane blades.
On the subject of sharpening stations and honing guides, I have a benchtop sharpening station with a horizontal honing wheel with a water drip and an adjustable-angle sliding tool rest/holder. While it's not quite as fancy as the Viceroy, it works well, and my planes and chisels are happier now with their bright new edges and backs, especially after I gave them a light touch-up with a finer stone. The adjustable orifice in the gravity-feed water drip works well, although the drip rate is more consistent if I keep the reservoir at least 2/3 full. I haven't used the left-side (dry) wheel yet, as I still need to order a replacement eye shield for it. The wheel guard for the left-side wheel can be rotated, and the tool rest/holder can be detached from the right side (horizontal wheel) and moved over and attached to a socket in the left-side wheel guard, which I think will be very handy for doing the initial grind on badly nicked blades. If I recall, the horizontal (wet) wheel is 1,000 grit, and the left-side (dry) wheel is 120 grit. I picked this up from a local bloke for $40 who was downsizing his operation.I still haven't modified the table to give a bit more clearance and I need to make a cover before fitting the table. In the meantime, I couldn't resist a little play using the reference surface (which I'd previously adjusted to be level with the grinding disc) with a honing guide to reshape and sharpen an old chisel.
That does look like it! Was about '61 or 2 and the odd thing was that it arrived with a big woodturning lathe. Good, but those were the only power tools in the shop. Bit overkill, as I thought at the time. The lathe was fun, doubt they would allow things like that now for young guys. Even the so called woodwork master was a bit wary of it, but didn't stop us... It wasn't a 'subject' for me, but hobby time.
How will you get the magic smoke in whilst the glue sets?After 1,5h of dismantling coming down to business.
TOP224 left its cover seals.
So try to find superglue to get it recover.
50/50 chance.
Man..How will you get the magic smoke in whilst the glue sets?![]()
This caught my eye: https://www.bricodepot.fr/saintes-saint-georges-des-coteaux/touret-a-meuler-250-w/prod58000/On the subject of sharpening stations and honing guides, I have a benchtop sharpening station with a horizontal honing wheel with a water drip and an adjustable-angle sliding tool rest/holder. While it's not quite as fancy as the Viceroy, it works well, and my planes and chisels are happier now with their bright new edges and backs, especially after I gave them a light touch-up with a finer stone. The adjustable orifice in the gravity-feed water drip works well, although the drip rate is more consistent if I keep the reservoir at least 2/3 full. I haven't used the left-side (dry) wheel yet, as I still need to order a replacement eye shield for it. The wheel guard for the left-side wheel can be rotated, and the tool rest/holder can be detached from the right side (horizontal wheel) and moved over and attached to a socket in the left-side wheel guard, which I think will be very handy for doing the initial grind on badly nicked blades. If I recall, the horizontal (wet) wheel is 1,000 grit, and the left-side (dry) wheel is 120 grit. I picked this up from a local bloke for $40 who was downsizing his operation.
Glad you sorted that, I was about to FedeX you some V high quality black pungent smoke. Works really well, if you know how to insert it...Man..
I thought you are specialists here.
got some black smoke from other machines….
That was quite easy.
That looks like a medieval torture device!Had a play at TIG welding this afternoon and it occured to me that it might be useful (for some) to have a wee rack for their tungstens should they dip and contaminate it; this never happens to me, obvs, but I thought I'd make an example just to show what could be done. Happened to have a block of aluminium kicking about, so eight holes later...
Please feel free to use this design, royalty free, as I thought some might need more than one tungsten if they're doing a weld longer than a few inches...![]()
Yeah... well, those that need that many tungstens racked up deserve it.![]()
Thought maybe you had pigeon problemsHad a play at TIG welding this afternoon and it occured to me that it might be useful (for some) to have a wee rack for their tungstens should they dip and contaminate it; this never happens to me, obvs, but I thought I'd make an example just to show what could be done. Happened to have a block of aluminium kicking about, so eight holes later...
Don't get me wrong, I stack up a few double ended tungstens myself, but sitting flat on the table or on the back of the vise where they can do less murder...Yeah... well, those that need that many tungstens racked up deserve it.![]()
Don't get me wrong, I stack up a few double ended tungstens myself, but sitting flat on the table or on the back of the vise where they can do less murder...![]()
And to be fully inclusive, here's the mirrored left pointing arrowBeen meaning to print one of these for a while-
A right pointing arrow.
I should really mirror it, and make a left pointing one as well.
