Looking forward to this...A simple balustrade on a stone spiral stair,the treads and wall aren’t level,my steel is though,
It’s genuine “ye olde”View attachment 293422View attachment 293423
To take you to your maker,lol.Looking forward to this...
Would love to make my own spiral staircase.
For what application, pray tell..Well I tried. God knows how it's going to turn out...
40kg plastering sand
10kg cement
5kg hydrated lime
500g black mortar tone powder
A litre of Everbuild Waterproofer in a bucket of water to mix it all up with.
...loads left over...whoops!
A square of 25x25x2.5 galv mesh pushed in with a couple of old M16 resin anchor studs held in with a couple of nuts and plate washers, this just to give a bit of lateral security when it sits atop the hollow brick pillar.
I used an old SDS bit cut down as a vibrator on the sides where the steel strapping is...didn't seem to work that well.
Forgot to grease the copper drip rail insert...
Cant really claim to have made.. as @Fraserb did most of the work... i only drilled, tapped and fitted 4mm studs to yhe back of them and epoxyed them to the holes in the wall
Spaced off the wall about 1/2"View attachment 293447
No... started with my smallest masonry bit.. maybe 2mm, then opened up to 5mm gradually.... was hard finding a wide enough bit on the letters to match where there was brick on the wallThe brick faces didn't Flake off when you drilled them...?
About 40 years ago I was painting a hull on a 1930s pleasure cruiser for a few quid in the back pocket from the owner.I knew from the LT designation she was a Lowestoft registered vessel and this is what I found on google: www.wildfire3.com/renascent.html
Lord Jings of Crivvens.Coping stone for a peer![]()
Do you mix the components dry and then add water or wet. If dry what about saving a bit of the mix to try as filler afterwards?Looks like it has potential. Clearly a few air bubbles got trapped but thinking maybe I can fill them with something?
