James1979
- Orkney
Thank youThat Orkney one is gorgeous.
do u just cover that now with plastic
That looks really goodThis something I made back in April.
I have been extremely ill since December 2019 and have not been able to do a full days work since then, which means my r-tech 250 has pushed less than 1X 15kg reel of wire in 18 months.
My adopted daughter lives about 2 miles across Norwich from where we do and she wanted to put her house on the market and move from her 2 up 2 down Victorian terrace with a tiny north facing garden albeit in a desirable residential area to somewhere else in Norwich with a larger south facing garden like ours.
No sooner had she decided to set about some of those little tidying up and decorating jobs done to make the house more sellable than Nomadic metal fairies stole her back garden gate. The gate was nothing special at all, just a cheap 30-40 year old Cannock mass made wrought iron gate. However, when Hannah moved into this house six years ago I had foreseen this particular issue and had replaced the cheap bolts and nuts used as the hinge for some grade 12.9 cap head bolts and nylock nuts thus I thought negating the casual two adjustables approach disappearing magic trick. I also thought I had thwarted all but a cordless grinder attack by cross drilling the nylock nuts and installing harden roll pins as a further measure of antitheft security.
I had not considered the cordless reciprocating saw approach as the Caravan Utilising Nomadic Travelling Scrap-collectors cut the wooden gate post off at ground level and stole it along with the gate.
For almost five months Hannah was without a proper garden gate and using an old pallet propped up to prevent both 5 year old Isaac and her 10 year old dog; Terra from escaping out the back and on to a reasonably busy residential commuter route.
As soon as I began to feel fit enough I made good my Christmas promise to her and started make a new gate.
I have inoperable kidney failure, my condition is not terminal but it is permanent as I we have found out that I am allergic to both general and local anesthetics.
Because of my condition, the oedema, elevated blood pressure, retained fluid, dry retching and breathlessness, etc. I can only work for about 30 minutes and then I have to rest for about 3-4 hours, and this really frustrates the hell out of me. Hannah's garden gate from beginning to end took me 5 days to complete; a job that normally would have taken me an afternoon and most of that would have been a tea break! .... and I didn't do the digging and concreting bit.
So here we go.
The new 75 x 75 x 3 box section steel gate posts. I've welded them to the 120mm wide flat because of the steps down from the garden to the communal back alley:
On the 1st of April I had got this far:
Rob & Paul did this for me on the 2nd of April.
Unfortunately I became ill again and it was the 22nd of April before I was well enough to start on the gate and the frosts had arrived her in Norfolk.
I set up a temporary work station in our garden and because Hannah was wanting to put her house on the market I decided to use some rusty old new stock that had been left uncovered and open to the weather outside my workshop for 15 months due to my illness.
05.45am on the 23rd of April, it's -2°C out there and the steel for Hannah's new garden gate is covered in frost.
It's 06.30am on Saturday the 24th of April, it's -2° C and the frost is beginning to lift.
The main fabrication has been done and in about two hours time I'm going to position and fix in place the the stop plate and hinges and drill and tap the holes for the return spring and catch.
My trusty R-Tech 250-1 mig welder has been left out all night under that green garden waste bag.
I can only work for about 30 minutes, I rushed and only rested for about 1½ - 2 hours between sessions. It took me all day to get to this stage and I made a school boy error: can you see it?
My adopted daughter Hannah stood proudly with her new gate at the pre-completion fitting to ensure everything is OK before painting it chocolate brown and final installation ready for her house to go on the market.
Back at ours and after a lick of ready Oxide the chocolate brown gloss has been applied.
View attachment 293323View attachment 293324
I forgot to take my camera when I installed the gate, so alas there is not a final photo.
I assume you're retired, to be able to put those sorts of hours in?![]()
When you said shogun lowering and water wall I pictures the weighing scales at the end of the water wall as a shotgun targetI made a water wall and I also made my shogun lower
View attachment 293384 View attachment 293385 View attachment 293386 View attachment 293387 View attachment 293388
and the water as a makeshift bullet stop! Thankfully that’s not what you’ve created!
Parts ordered during the week, on a works slow point.I'm always amazed at how you take something that looks crappy, and turn it into something desirable. And it never seems to take you all that long, either... I assume you're retired, to be able to put those sorts of hours in?![]()
photos @The_Yellow_Ardvark ...Parts ordered during the week, on a works slow point.
Striped Thursday, repairs on Friday evening, paint and more repairs on Saturday.
Small jobs Sunday, assemble Monday and steamed.
Thank you for your kind commit.
Go see my Mamod rebuild @Barking Matphotos @The_Yellow_Ardvark ...
I've seen it, liked it, probably catching up on a unreviewed thread, .....Go see my Mamod rebuild @Barking Mat
Or out of beer.I've seen it, liked it, probably catching up on a unreviewed thread, .....
No danger of that...Or out of beer.
