Is that an Arboga?
Yeah, an a2608 I got off my uncle a few years back. I sometimes want to upgrade it, especially if I'm running big cutters in it, but it's been sweet on 18s and 14s recently.Is that an Arboga?
I rate Arboga drills, they don't look much, especially the older ones like I have but they are hard to beat in my opinion.Yeah, an a2608 I got off my uncle a few years back. I sometimes want to upgrade it, especially if I'm running big cutters in it, but it's been sweet on 18s and 14s recently.
The older ones were superb.I rate Arboga drills, they don't look much, especially the older ones like I have but they are hard to beat in my opinion.
Not sure I follow, are you meaning the coolant or the tool holder?Time for remodeling or is it not viable?
That wouldn't work, the lower seat and the insert have multiple grooves and the top has a single. The wider insert has 1 more groove than the narrower one so the lower grooves and the top groove don't line up on the holder with respect to the thinner insert.The tool holder .. You've got the machinery to shave 0.5 mm off each side of the cutter holder ?
I like this...Finally drilled the holes in my welding table. This was a bit of a trial run for the Mag Drill. I am going to drill the hot bench next but I have a plan, total overkill but it will look good. This is the table and some Kennedy F clamps modified a la @Tangledfeet :
Table folds up nicely flat against the wall. I was very pleasantly surprised at just how accurate the holes in the table turned out.
I like this...
I think I shall be doing a copy...Thank you, copied from a picture of a trendy Ikea table on the web.
The bar at the back is at 90degrees to the table so a clamp there clamps the workpiece square to the table surface. I must say, I did impress myself.
Brilliant, please do and thanks.If you need any measurements let me know. I will take a pic of the underside if you like?
That’s really smartWell not today but just before I collected the Centec.
Following on from @Hood putting a DRO on his tailstock I invalidated the Lidl guarantee
Then did a bit more to it, fitted a magnet from an old hard drive and made a clamp!
So it fits like this
