Now that sounds good. Not sure if my local supplier has that size in. But I will ring and ask.Wall thickness I said above is incorrect: should have said 5mm.
3 1/2" (88.9mm) OD x 1/4" wall is available. That would give 3" or 76.2mm bore, so would need boring out to get the 80mm you need leaving just under 4.5mm wall.
88.9mm x 6.3mm (3 1/2" x 1/4") Aluminium Round Tube
3 1/2 in x 1/4 in Aluminium Round Tube in Stock Now. Bulk Discounts. Buy Online or Call 0800 520 0729. Top rated Supplier.www.aluminiumwarehouse.co.uk
Yeah that's the supplier I meant. I used them when Droitwich Aluminium had not got what I needed.Try:
in Smethwick, so not far from West Brom.
Edit: 90 x 5 metric tube (expensive) https://www.ebay.co.uk/itm/254627829193
No not a lot. Approx 12 inch lengths .Are you needing a lot of it? I may have some small bits left off a job but won't be a massive amount.
I used it for the davit arm on this boat and I am fairly certain it was 3.5" x 1/4" wall.
It was our measurement system firstPretty sure aluminium is sized as imperial ,thank the yanks.
Yes,but thank them for retaining its use.It was our measurement system first
It’s far better than metric for a lot of stuff.Yes,but thank them for retaining its use.
