DanielW
- Merseyside Straightjacket user
Think 8mm would be to big as you will loose the pressure. I to searched ebay and used the term "ceramic cylinder" and there were some at about 3mmi inside dia which is closer to the Wicks lance.
Just an FYI guys..
There is a phenomenon called Hydrogen Embrittlement that causes high carbon steel to become brittle when exposed to Citric Acid. I came across the term on Trevs Blog.
He says not to use it on things such as brake discs, wheel hubs etc.. I've used it on my wheel hubs and rear discs. I'm not sure worried about rear brakes as they aren't really used due to the bias. I am wondering should I bin the hubs.. :/ I need to research but it sounds like that might not be necessary.
Hydrogen embrittlement - Wikipedia
en.wikipedia.org
Just an FYI guys..
en.wikipedia.org
Bloody hope not, i did a job lot of rusty morse taper drills a few weeks back with citric.
Baking, that was niggling me as something I remember reading about.There's no lack of info about hydrogen embrittlement on the net. Citric acid doesn't seem to be of great concern, but hydrogen can be "baked out" by holding the metal at (say) 200'C for some hours; it all depends on the particular situation.
It can happen with any acid......the definition of an acid is "An acid is any hydrogen-containing substance that is capable of donating a proton (hydrogen ion) to another substance. A base is a molecule or ion able to accept a hydrogen ion from an acid"Just an FYI guys..
en.wikipedia.org
