Hood
- Carnoustie, Scotland
I retired in 89 right enough, 1889Shows how old you are you forgot buying it new and selling to me when you took late retirement in ‘89
Some from when I bought it and a picture of my oldest machine that works for a living a 1930s LangPhotos please!
Probably my Centec from 1954, though plenty of my hand tools will be older
The Matchless in my profile pic was built the same year.
Not sure what year my Fobco is and my Myford is a modern 1973
I bet your van knew it had that in the back. Mine is heavy but yours is a monster.Some from when I bought it and a picture of my oldest machine that works for a living a 1930s Lang View attachment 288903View attachment 288904View attachment 288905
the motors are 440v single phase and 240v single they do run on 2phases as well. quite comon to have on rural farms that didnt have 3 phaseOldest machine i use is my Romac Air compressor, Built in 1944 It is a strange beast, ex CEGB designed for paint spraying with a 1.5hp 2 phase motor, can be run on 240 or 440 volts though i have it set up as 240 only.
Luckily it’s a 7 ton vanI bet your van knew it had that in the back. Mine is heavy but yours is a monster.
Oldest machine i use is my Romac Air compressor, Built in 1944 It is a strange beast, ex CEGB designed for paint spraying with a 1.5hp 2 phase motor, can be run on 240 or 440 volts though i have it set up as 240 only. Swash plate pump with six axial cylinders arranged like the cylinders of a revolver.
Air tanks are a twin underslung arrangement made from 16mm thick tube & still clean & greasy inside. It was touted as a mobile unit but is hugely heavy so doubt it got wheeled about much!
