Hopefuldave
Intergalactic pot-mender
- The Shed of Danger, surrey, England
Knockers out... for Honda lower balljoint, and pushers in! I'd be using them if it weren't Persisting Down...
Dave H. (the other one)
View attachment 287155 View attachment 287156
Well, got to find things to do with the lathe, eh?Nice job there.
We used to just use gas and a socket. Then air line to chill once new dropped into place.
Should be able to press them out/in in the Big Vice, I suspect?
It looks good to me! I had to tighten up my gibs on the Y axis as I got some chatter on a previous job. Mine is a Centec 2b and I can recommend one thoroughly! It handles a .300" wide cutter at .200" deep cut with no problem. The picture above is a .020" cut at .300" wide on the arbour. I don't have any shell mills (at present!) but will remedy that shortly^^Looks better than my very amateur offering.
Its certainly slow going taking out the radius on the edges, especially as I know not what I’m doing.
The side only half done is with a conventional cutter and I got what amadeal calls a roughing shell mill. It is definitely a rough finish and there is some play and chatter, I think although I locked the y axis. It’s probably a bit big for my mill but I think I’ve found a Centec 2B.
Also had to make a fixture plate out of some 10mm plate and dowel pins as it’s too long to do in one go.
Cheers. The 2B has no cabinet and has a supplied 3 phase motor so I’ll have to either go vfd or get a different motor.It looks good to me! I had to tighten up my gibs on the Y axis as I got some chatter on a previous job. Mine is a Centec 2b and I can recommend one thoroughly! It handles a .300" wide cutter at .200" deep cut with no problem. The picture above is a .020" cut at .300" wide on the arbour. I don't have any shell mills (at present!) but will remedy that shortly![]()
My Centec is the bench type but the previous owner fitted it onto a standard mill base. I have a single phase motor fitted fortunately. I would remake or repair the c spanner nuts as you are fighting that. I lock the other axis and as there is some wear on X I add a bit of drag with the X lock whilst in the middle part of the table. Here is a pic of mine sat on its modern plinth.Cheers. The 2B has no cabinet and has a supplied 3 phase motor so I’ll have to either go vfd or get a different motor.
The arbour for the shell mill came from arceuro as they seemed the cheapest I could find.
The chatter I’m.getting seems to be side to side and you can see the table shaking, a bit like a seed dresser. Is that likely to be the lead screw worn? The locking collars(?) on the end should take a c spanner but are pretty beaten up making adjustment a bit of a sod.
Oh yeah? Care to expand? All of these lovely centec 2b posts are making me very envious!I know of a nice small mill
A friend of mine now too ill to be stood in a cold shed unfortunately. Very well looked after but I can’t remember if it’s a small Elliott or a Tom senior. It’s 30 INT taper so very rigid for a small machine.Oh yeah? Care to expand? All of these lovely centec 2b posts are making me very envious!
That's a shame they can't use it. Does sound very interesting though! Do you know what area of the country they're in?A friend of mine now too ill to be stood in a cold shed unfortunately. Very well looked after but I can’t remember if it’s a small Elliott or a Tom senior. It’s 30 INT taper so very rigid for a small machine
Essex.That's a shame they can't use it. Does sound very interesting though! Do you know what area of the country they're in?
Essex.
Always sooooo far away.I think they wanted a small small mill not a big small mill, said he with a small small small mill.Always sooooo far away.
Someone posted today, looking for a small mill.
I’ve spoke to the owner but he has changed his mind now. He does want to move his J&S 540 on though which I had forgotten all aboutAlways sooooo far away.
Does he want sensible money for it ot eBay prices?I’ve spoke to the owner but he has changed his mind now. He does want to move his J&S 540 on though which I had forgotten all about
Sensible.Does he want sensible money for it ot eBay prices?
