julianf
- devon, uk
Using this corrugated sheet material -
www.cladco.co.uk
With a maximum unsupported purlin distance of 1.6m, how do i know the strength of the purlins to use?
The datasheet gives the purlin spacing of 1.2m, but, so far as i can tell, gives no information as to what material should be used for the purlins themselves.
Obviously this is dependent on distance between the a-frames, so one size will not fit all, but how can i calculate the purlin requirements for my 1.6m span?
I want to keep the total weight down, so i dont just want to go bigger (heavier) than needed, otherwise id just overengineer it anyway - but, again, i dont want to increase the weight.
Thank you!
32/1000 Box Profile 0.7 PVC Plastisol Coated Roof Sheet
<h2><strong>Uses of 32/1000 Box Profile PVC Roof Sheets</strong></h2> <p>Cladco 0.7mm PVC plastisol coated roofing sheets can be used for a range of installations including commercial, domestic or agricultural. Profiled roofing sheets can be used as a single-skin sheeting, over clad of an...
Thank you!
