Hood
I am obsessed.
- Carnoustie, Scotland
Where the parallel port starts to fall down is when you are using servos rather than steppers due to the pulse requirement of servos. As an example my Plasma has approx 1700pulses per mm and a velocity of 20,000mm/min so that means I need a pulse rate of approx 567KHz which is more than 10x the reliable pulse rate (45KHz) that the parallel port can output. Yes you can do electronic gearing within the servo drive to reduce the requirements but that may or may not be ideal.
Another thing about the parallel port is it is 5v (more often 3.3v or so) and that can be problematic for noise, personally I much prefer to have everything , I/O wise, at 24v
. Since I have had a few issues with mine (Gecko 320 drives) I now realise the complexity of servos. I will still admit that I don't regret getting servos over steppers, it is something you have to learn about, it is just a shame that I have to deal with Americans, that at best will answer one question at a time, regardless of how many have been asked, and hopefully answer what you have asked in a way that you/ the user can understand
. Very frustrating and not to mention you have to be nice about it or you won't get an answer. They are not all the same, but I can understand why they are not the most popular around the world.
