the material I’m trying to weld is 1.5mm 1050 H14 grade plate
If it goes blue then the shielding is probably not terrible, but you'll need to up the post gas flow a couple of seconds. You want that tungsten shiny...Hi munkul, the tungsten goes blue at the end and a ball appears(started of sharpened), I will try what you said later when I get back from work bud, I really do appreciate your help
but seriously, best advice from this forum for a beginner is to keep that tungsten clean at all times, especially on AC. It makes things easier, eliminates variables, and gives a more stable arc. Once you have a bit of experience you can work out what you can and can't get away with.
