Have you got a link to them on amazon please?Yes I have two sets from amazon, they were £5 for a 3-12mm H7 set and £7 for a 3-10mm H8 set which I havent used yet.
H7 is generally +0.2mm, so clearance holes.
H8 is close fit.
The h7 holes measure good with the ball gauges, in my opinion. Wouldnt want to rely on them for anything safety critical but remember its a £5 set rather than £15+ each that the branded ones cost. Ive got a few branded ones, they cost £10 each used.
H8 is close fit.
H8Which would be preferred for reaming out a bronze bush for a rotating shaft; H7 or H8?
I suppose really you need to measure your shaftand see what the tolerance is.
it it Oilite or Phosphor Bronze. Oil or grease lubrication?
It only works if you make both pieces to the correct tolerences. Its in the zeus book. So the fit would be something like H7G6 denoting two parts.I dont claim to understand the ISO fits system, but most of them seem wrong (not your chart, the system!), example being force fits, why would you have a +0.2mm hole for a force fit as it means you need a +0.25mm shaft. Please can someone explain it with an example or two.
...the fit would be something like H7G6 denoting two parts.
Or get yourself one of theseCheck your tailstock alignment because that will throw a reamer out if the tailstock is out of line or ******
Cheers mateHeres the links, not available from the same seller and tbe second price has gone up. It took quite a bit of searching to find the H8 set.
www.amazon.co.uk/gp/aw/d/B07V4747BW
www.amazon.co.uk/gp/aw/d/B07VWVH8XL
what is it?
