MattF
- South Yorkshire
they only go up to about 10mm thick no use in a bore though. there tapered not measure by length you slip them between a gap till it goes tight on the taper and it gives you the thickness needed .
Honestly, bore gauge.
Example:
Kennedy 15-30MM Taper Bore Gauge 1511B | at Zoro
Kennedy - 15-30MM Taper Bore Gauge available at Zoro.co.uk - UK's Leading Supplier of DIY Tools and Supplies'
www.zoro.co.uk
