If you did them as tab and slot, would it be possible to make the welds invisible in normal operation?
Some rainwater storage capacity,relevant as there’s 5 of us and on a meter
Nice, I need to do similar only I don't have the materials hanging around or a mahoosive drill press.Something I’ve been tripping over materials for months, finally found a bit of time to stick them all together.
25t capacity, need to manufacture the plates for the parts to sit on but otherwise complete. Might give it a coat of paint but it’s not high on my list of priorities...
150mm channel with 1” pins, hopefully it’ll stay in one piece. Weighs a chuffin ton! Couldn’t lift it onto the bench in one, had to split it down.
Threaded bush machines out to match the jack body, tacked to a backing plate which is tacked to the upper beams. Shouldn’t need anything too substantial as it’s all in compression during use.
luckily I have a 70 year old drill so the 26mm clearance holes were nice an easy to drill, and unlike modern Chinese drills it has the capacity to go right through without having to drill a pilot in the bottom and lift the table up every time for the depth!
Had a good amount of weight on it already but I can’t load it up because I don’t have anything substantial enough!
A few houses down had mains pipe leak in garden. Water supply didnt bill him for it, but Thames water use the readings too, he had a massive bill from them for surface drainage? Even tho it would just be running down short hill into the local pond.You might already know this but if you can show that you do not discharge your rainwater into the foul sewer, you can ask for a small reduction on your water bill.
Haven't a clue about electrickery ( and most other things) what does a diode exactly do?![]()
Thats better, Thanks.Best description (or comparison) of a diode is to think of it like a funnel: the water (or electrical current) is happy to flow through it one way but can't do so the other. Even the electrical symbol for a diode looks like a coffee filter holder![]()
The bottom machine, I have her twin sister, she is very happy here at my place
What's the dice?Was asked to do the hoovering done this instead View attachment 281389View attachment 281390
There may be a delay to mk2, I've forgotten an important ingredient for the Sunday roast.
If the battery polarity was wrong, that would have instantly exploded the diode, but Id expect it to take some time for the mosfet to fatigue from spikes.@Kram, so what do you reckon killed this Duratool multitool. It's 18V and the Makita battery is 18V. As I said the only thing I can think is the Ah on the Makita battery was too high.
D'oh..Right...I don't mind admitting my mistakes...
My finger is on the positive of the battery....spot the mistake?
Htf did I manage that? By getting the polarity marks the wrong way round on the 3D print!
Just the diode died d'you reckon?
Ive done the same and worse!Right...I don't mind admitting my mistakes...
Have you tried it correct polarity since? If the speed control still works, then just replace the diode![]()
Material?What's the dice?
Very nice my friend.
