badabec
- Essex UK
Do you like hospital food?Could you do one that says "Swmbo"?
]Not quite a cockup (yet) but I had forgotten that the nozzle needs a tapered seat to match the needle. As I dont have a working lathe or anything suitable to cut taper, I thought I'd lap it using the needle and a spare. That didnt go to plan, die grinder collet is poo and it worked its way out and got me in the shoulderView attachment 281034
Enlarged my GF3 mini gun 1.2mm nozzle to 1.55mm. They dont make bigger nozzles, you'd normally have to use thinners or buy a full size gun. I'll be attempting this gun for primer, it seems 1.8mm is recommended but I'll test before going bigger. The OD is 2.6mm. Might not work but I dont see why it cant.
Lathe headstock stripped paint off. Suprised they face milled the casting to be square, tho its rough. Doesnt look too bad under the thick green paint.
Diodes are easily replaced. Usually there for clamping motor back emf. If thats
If it runs only at full speed that does mean the mosfet is blown, they usually fail shorted. In other devices where the current is not limited by a motor, they can make a very big bang.
Diode spec your looking for reverse voltage and recovery time.
Mosfet any 20A+ N type should do. If you are buying one of the switches for your drill, you could take the old mosfet from that.
Time for pie,chips battered sausages, scraps and a pair of baps.
