The HETAS engineer that installed ours recommended choosing one with with the option for an external air intake as our chimney is on an outside wall. Seems like a good idea, otherwise you get a draught where air finds its way into the room.
ps. i considered room sealing ours, but we live in an old house with stone walls, and no damp proof course, etc. and i figured a bit of air turn over was not a bad thing.
Valor riddlington 8kw had it 10 years with very few problems and the parts are available
Definitely welded. We've had ours 14years no probs. My daughter has 2 welded stoves too. Absolutely no problems, remain airtight for easy control. Cast iron stoves expand and contract, as do steel, but cast are joined by bolts at the corners, the joints break down and they need rebuilding periodically. Look for a cast iron door though, for rigidity and good sealing
Think if my budget was under £1000, I'd definitely be looking at s/h or refurbished. In reality,
I don't buy my wood. I generally get it given. I collect, cut and split it myself as I have the gear. It's secondary heat source for us as we have gas central heating. Heating goes off at 6pm and we put the stove on if needed for the evening. Generally we use 2-3 ibc cages of logs per winter. I season them in the cages for at least 2 summers then put them in the shed, where we take them from to use for the winter. I learned long ago to season my own logs as we initially bought them and there was no heat from them. So I work 2 years ahead, if I was short and had to buy them in, I would still season them for 2 years myself. My stove is a town and country welded stove, made in Malton, North Yorkshire.may i ask all these members there wood usage in cords of wood or do you mix material use in your stoves ?
I also noted that you didnt say your model of stove being used
try the blocks from the blue pallets, they give a nice blue flame!Got a biggish stove that will take logs of around a foot long, no shortage of decent wood but I have found its better with our stove to mix in a few sticks of slower burning rubbish like willow with the oak or ash . Only need to top up the stove once or twice of an evening.
Bob
aint that the truth! mine is lovely for 3 or 4 hours then i have to sit here in my birthday suit, the bedroom also becomes like a sanua too as the chimney breast is in that roomIs the room large enough for a stove? I really wanted one, going to the trouble of building a store and collecting wood. In the winter my wife likes to light tea-lights (don't ask), with about 30 of them alight, the room was too hot. They are about 30 watts each, so nearly 1Kw. That experience quickly put paid to a wood burning stove. We just flick a switch these days.
i could never purchase wood to burn on my log burner either! no way cheaper to turn up the gas fired boiler!If you have to buy wood go gas or oil it is FAR cheaper.
I live in a very rural area and for they amount they charge for wood it would cost me about £200 a week if I had to pay for it!
Scrounging your own is the only way to go.
I love my woodburner but being truthful they are very polluting and make no sense without the free wood.
I have unlimited supplies of free pallet wood - not the planks but the thick side bearers and blocks.
Whatever you do dont burn MDF - very nasty chemicals and it stinks.
lizard lol i like to be in nothing!Builders yard offered once to deliver me all their waste wood.
I just don't have the space for that, but it did make me think about either building some large incinerator style thing, or a shredder and an auger feed.
I like to be able to ware a t-shirt indoors all year round. And I'm like a lizard - if I start to get cold j just get inactive. Even if I've relented and put on a coat!
I don't stack I just chuck cut and split logs in. Ibc is 1000 litres. Usually I have them heaped about a foot higher than the top.. As they're randomly chucked in, and air can get around them, I think they season better.thankyou for answering so far guys
i had to go and look this up so ibc container full of wood contains in cords of wood
There are a few choices.
Take A x B x C / 1728 to get Cu ft. Then take that divided by 128 to get cords.
ex. for a 300 gal tote 42x48x41=82656 in^2/1728=47.83 ft^3
47.83 ft^3 /128 = .374 cord.
If you heap it you can probably get just under 1/2 cord in it. All of this assumes you stack it neatly which will probably necessitate cutting one side off to allow for uneven wood.
plenty of nails to pull out the grate!Yeah, the planks are tinder. The best pallets are the ones with the thick runners - easier than the ones with the squares at the corners to pull apart and a decent amount of wood.
Euro pallets burn a good while, and are worth having but more effort to chop up.
You use far more than that if you rely on wood only. That would last me 2 weeks tops.I don't buy my wood. I generally get it given. I collect, cut and split it myself as I have the gear. It's secondary heat source for us as we have gas central heating. Heating goes off at 6pm and we put the stove on if needed for the evening. Generally we use 2-3 ibc cages of logs per winter. I season them in the cages for at least 2 summers then put them in the shed, where we take them from to use for the winter. I learned long ago to season my own logs as we initially bought them and there was no heat from them. So I work 2 years ahead, if I was short and had to buy them in, I would still season them for 2 years myself. My stove is a town and country welded stove, made in Malton, North Yorkshire.
