peterd51
happy to be here!
Hi,
the hovercraft trailer that I made a few weeks ago needed a jockey wheel, and I found a bit of pipe kicking around the workshop...
So I cut out some side pieces to hold one of the spare wheels that I have laying around.
then I welded a couple of strips of 5mm plate onto the end of the tube to widen the gap enough to take a wheel, and welded on the wheel-legs at a bit of an angle so it worked like a caster.
After cutting the end off, I got a couple of thick washers and joined them together with a nut and bolt. This was left loose enough for the washers to turn freely without being slack and I put a couple of spots of weld on the threads. One washer was then welded onto each piece of pipe
After a coat of black Hamerite and a week in the airing cupboard to dry off while waiting for the rain to stop...
I finally got the clamp welded on yesterday morning...
Regards
Peter
Regards
Peter
