it was well used but still cut .stuck an 18 in it and it was hopeless so changed it for the 24 and was ok
Now the next question
what TPI do I need. Just tor general purpose metal bashing at home
I use 24 tpi cos they were a freebie.for metal bashing.........think you'll have more success if you use a hammer![]()
I have two hacksaw frames and have a 18tpi blade in one and a 32 tpi blade in the other one. You can get 14tpi ones too if you want a courser cut
The were all eclipse HSSWhat make blades did your Grampy use Parm? I have a stock of old Eclipse blades and Bahco mentioned above I would favour as replacements. 3 teeth minimum in the thinnest part to be cut from memory. I have a collection of hacksaw with blades from 6 to 32tpi. Bi-metal are nice in shared saws.
24tpi if your cutting a lot of thin stuff and plastics and 18 for thick stuff . get some of each if doing both . i have 4 frames so 18tpi in 2 of them and 24 in others get a pot of cutting compound and smear blades with it . they cut faster and easier and blades last longer
hi i use the original brown rocol not the newer red chlorine free stuff or use templars or trefolex i use it when drilling steel threading and sometimes rub a bit on the job in the lathe on the last cut Trefolex Cutting Compound | Cromwell Tools . i use it on my mechanical hacksaw blades and rub some on the part im cutting as i havent a water feed on it and dont want white water all over the placeHello, can you possibly recommend a good cutting compound to use? Excuse my ignorance but i never thought to use anything like that with a hand hacksaw so i'm keen to try it.
Excellent, thanks for that much appreciated.hi i use the original brown rocol not the newer red chlorine free stuff or use templars or trefolex i use it when drilling steel threading and sometimes rub a bit on the job in the lathe on the last cut Trefolex Cutting Compound | Cromwell Tools . i use it on my mechanical hacksaw blades and rub some on the part im cutting as i havent a water feed on it and dont want white water all over the place
Lol, my work cupboard only has paper, pens and note books, lol18tpi Bahco blades in the consumables cupboard at work.
Oddly enough, I use the same blades at home.
Used mostly for cutting 2mm wall stainless pipe.
