James1979
- Orkney
I am hoping this thread doesnt end in "Today I acquired..... a hernia"!!It's off to Orkney to be put to production work again. And yeah. A member
Done for the day Boss.I am hoping this thread doesnt end in "Today I acquired..... a hernia"!!
Do you have a link? I’d like one of those too!
Spot on cheers.Done for the day Boss.
Framed and braced. No point in diagonals as the ply will do the job.
May change my mind Monday but il see as I cover it.
Will also add a point to the top.
Stop some dozy twonk stacking a pallet on top.
Il wrap and load all the bits Tomorrow and as I've ended up with some free time up board it up Monday to keep the neighbors off my back.
1200w X 800 deep X 1350 high.
Not a clue on weight. I'd say 600 ish
Oh and taking that pic reminded me to clean the tray a bit.
I won't be able to fit the iso32 on the pallet mate. Wanted to keep the lathe central.
View attachment 280073 View attachment 280074
The police are hot on it here to the point of obsessive. Loads of my mates have been done.Big thumbs up for tilting the tines back.Makes me whince when I see them poking forward.
Is there a specific offence for leaving them down.The police are hot on it here to the point of obsessive. Loads of my mates have been done.
They are not hot on very much else so I have no idea why. I really dont like to see times and spikes sticking forward. Dangerous all round.
What if you haven’t got flip back tinesYeah, "forward projecting tines' or something. Its normally about £600 and a load of points. It specifically refers to tines as far as I know so implements other than tines are a grey area.
reverse thereWhat if you haven’t got flip back tines
You can get away with it if they are guarded. People put a pallet on which you can get away with it with but then what do you do with the pallet?!What if you haven’t got flip back tines
Yep spring calipers should be called “nearly there calipers”I thought I'd see what this digital internal caliper would be like... unfortunately it's **** pooronly measures to 0.1mm and it's out by that much too. Waste of time for anything other than rough measuring.
Cheers, yeah I'm familiar with telescope gauges and micrometers as I used to do a lot of bearing fitting and some engine rebuilding... Got a few very nice micrometers from years backYep spring calipers should be called “nearly there calipers”
I think you said you already have a set, but the only thing to use really is snap gauges/bore gauges.
You need to get yourself a setting ring/standard and take a few measurements to ensure your technique is accurate and then you’re good to go. The feel of the mike is important when working with snap gauges, I’d say I prefer a mechanical micrometer to the digital Mike when measuring snap gauges.
if you’re working on something then same size again and again, then I’d recommend either Tesa or Mitutoyo three point bore micrometers. Expensive to cover a range of measurements though.
