Misterg
- North Wales
I'm still messing around practicing on thin aluminium. My tungsten end up looking like this quite often:
Is it sufficient to re-grind the tip to give something like the (blurry, sorry) photo below?
If I need to remove it all, is it worth trying to grind it off, or is it a case of cutting the tungsten above any discolouration and re-grinding? It undoubtedly looks better that way, but I'd go through tungstens very quickly!
Advice appreciated.
Advice appreciated.
you can get away with just cleaning the end, and grinding the rough off further up, as the arc will eventually burn off the aluminium if its not on the tip. It's not "right" but you can get away with it if the contamination is light.
