Pigeon_Droppings2
- london
I have the same one...I use it for all sorts of stuff where you need heat but controlled temperature. Things like getting glue to separate on trims etc etc....well worth the money I think.
To elaborate furtherI'd 'like' that, if I knew what it was/did....![]()
For under 50 quid I'm not complainingI have the same one...I use it for all sorts of stuff where you need heat but controlled temperature. Things like getting glue to separate on trims etc etc....well worth the money I think.
I looked at a dual use setup, going for the t12, as I didnt want to drag the hotgun around at the same time. Good for bench work though.For under 50 quid I'm not complaining
As a bonus it will drive the iron and hot air at the same time. Wasn't expecting that
The GTE Coupe is one of my favourites.It is indeed a Kadett C
Nope, although they were effectively the same shell from the A pillars back
Well, I haven't got it yet, because I am still building it. Update later.
Those look quite smart. How smooth are they in operation. Not very impressed with my mitutoyos which were about twice the price of those starrettsView attachment 278946View attachment 278947
As in my other thread - a set of starrett bore gauges.Not sure I can do them justice with my ham-fisted attempts at metal mangling but I’ll give it a whirl
Seem pretty good to be honest, I’ve not used them in anger yet but a quick furtle on the bench doesn’t indicate any notchiness or slop. The overall “feel” seems nice, which is always a bonus - the last set I used were a no brand cheap set and while I’m sure they did the job just fine they always felt a bit notchy and rough.Those look quite smart. How smooth are they in operation. Not very impressed with my mitutoyos which were about twice the price of those starretts
Next step in making the 3D printer a little quieter, it's a 24V Meanwell fanless power supply from RSView attachment 279014
Rotary encoders.After 8 years of faultless use I had a minor issue with my Kemppi 200 Evo. The Kemppi has 2 controls...one sets thickness and the other sets a trim adjustment on wire feed.
The controls are super accurate and each click changes the settings....but my thickness setting started jumping.
To get by I simply swapped the "pots" around (wire trim is less used as the synergetic setting is usually close enough)...manage to get replacements but they were hard to find. I suspect these bits have been discontinued and there is probably a new equivalent....welder is working with my quick fix so there will go into the spares cupboard.
The whole board (with pots on) was around £300.
I've referred to them as "pots" but they aren't actually potentiometers...they are some sort of digital encoder I'm guessing which gives very precise adjustment so each click precisely adjusts the settings. So if you did 10 clicks one way and 10 clicks back you'd be back to where you started....quite clever.
Is hugging allowed?.....shame it was socially distanced!
