Not worried about uv as rats will chew through it first so will be replaced often and it is cheap so i can. Going to use 20mm stuff for now and 25 later on .You need to make sure its rated for uv exposure, it's fine with air in it but I've seen thw stuff that's meant to be buried crack after being in the sun for a few years.
20 or 25mm pipe and for what i am doing at the mo 20mm and its fittings are perfect.I do between workshops
could you cover it in pipe insulation would that help ?
Not a problem with air as it's compressible and also low mass. Certainly not at the flow rates involved anyway.have a little read up on 'water hammer' and consider if the same thing could happen in your set up and the consequences if it does.
Water Hammer is not generally a problem with compressed air systems because air is compressible
Kinetic energy is Ek = 1/2 mv2The reason I suggested he think about it is if he has 8 bar of air at full flow through the line (maybe he is blasting) and then closes the valve, will the pressure spike come uncomfortably close to the 12 bar rating of the pipe?
