Myles1970
- Monaghan, Ireland
Good, I'm glad..... I've wanted to do something like this since forever, but in the end I decided to just pull my finger out and get on with itgreat work Miles and inspiration to me.
it's a zinc primer...hopefully it'll serve to preserve until i'm happy with the metalwork from the windscreen forward. After that I'll key it and seal it with epoxy.Is that just normal primer you're putting non the car in the last pic of post 121?
Speaking of welding panels, here's the leading edges of the rear wheelarches:
View attachment 277082View attachment 277083
There's repair sections available at the moment:
.... but I'm thinking that I'd prefer to fab the small bit that I require... View attachment 277084
And here's two strengthening gussets for between the front strut towers and the bulkhead...
Good shout will add it to the to the shopping basket
Those repair piece don't look that hot, I'm certain you will do a better job starting from scratch.
I didn't actually but must be infinitely better than leaving bare metal showing like I admittedly have had to do.at primer is porous, so this is for the short term while the shell is in the garage...I wouldn't risk it otherwise, even at that the garage is
yea, I'm sure you're aware that primer is porous, so this is for the short term while the shell is in the garage...I wouldn't risk it otherwise, even at that the garage is far from a perfect environment, but it's better than bare metal
16mm....was thinking of dimpling them, but they might be water drains...For scale are those homes 8mm?
What was the body panel l like here? Did you cut it out to get to the inner arch or was that goosed also?
The top of my archs are similar to this so I'm wondering if you did it for the access or because nobody wants to weld upside down
Also the little flap of extra material you welded in is that copying something that was there already or is this to allow you to weld up to the edle of the material with less risk of blow through?
