I had exactly the same question years ago...I think the conclusion (after a lot of google searching) was that transportation on it's side isn't a problem but I recall somewhere saying it must be upright in use and maybe it has to settle for a few minutes before use?As above is tanks supposed to be transported upright and will it do harm on its side?
Disolved acetylene is the only gas where it does matter.
Haha i love the fail safe, i just hope that isn't the approved solution in bridge building..first thing I do is make a cuppa...if its still in the air when I get back its probably ok!
From the horse's mouth.BCGA said:Secure cylinders. Cylinders shall be restrained so that they cannot move during transport. They shall not project beyond the sides or ends of the vehicle. It is recommended that cylinders are transported vertically, secured in an appropriate pallet. NOTE: Other items in the vehicle should also be secured such that they do not come into contact with gas cylinders during the journey. Certain cylinders should only be carried and restrained in a vertical position, for example, liquefied gases, such as LPG. This action will ensure the valves are uppermost allowing the relief valve to connect with the vapour space inside the cylinder. For cylinders containing a dissolved gas, such as acetylene, a vertical orientation will prevent the escape of the liquid (acetone) in the event of a leak
The only people who can afford the cages necessary for larger upright cylinder transport, are the gas companies themselves
Note that propane tanks are generally horizontal on stacka trucks, so obviously there are exceptions to the liquified gas rule, not sure where or how though![]()
I see, fair enoughFork lifts have special cylinders that can decant horizontally. they usually have an "up" arrow also. probably just a dip tube internally.
I’m a bit like thatAcetylene needs standing up for at least the same time it was lying down Before use, that’s the rule of thumb I was told.
I’m a bit like that
You need to make yourself one of theseplanning to do this on monday just getting the thing in the back of my pick up seems to be a lot harder than it used to be
