I used to visit car and bike dealers who had their parts dept running the same system It worked well until the storeman went sick and the dealership couldn't operate. Not the same situation as yours but used to make me smile.Oh bother.
My way is to have it organised in such a way only I know were anything is.
Bob Missons used to be the same.I used to visit car and bike dealers who had their parts dept running the same system It worked well until the storeman went sick and the dealership couldn't operate. Not the same situation as yours but used to make me smile.
R.I.P Greg and Keith. They were one of my calls and I could never understand how they worked in that workshop in the winter .Bob Missons used to be the same.
The Rose and crown On the bridge helped.R.I.P Greg and Keith. They were one of my calls and I could never understand how they worked in that workshop in the winter .
)I bolted my "walkabout " vice to an old van brake disc and the when I want it secure I just use a couple of G clamps to whatever surface is handy.View attachment 274490
Bending some alu sheet for a pcb enclosure. Vice bender put plenty of scratches into the annodising and I need a removable way of bolting the vice to lathe bench.
Also swept the floor - I know where everything is, and it wasnt in the bit I swept! (Dropped some inserts last week)
I only re-organised because we moved house. Now I have to figure out where everything lives again, hence the labels.Please don't EVER be tempted to have a re organisation Its a sure way to Insanity. I did it at the beginning of all this virus thingy and I now know where everything USED to be.
That's why I've never done it before but I reckon making ten at a time I could do them a bit quicker. Would probably save a bit of time starting with annealed sheet rather than 22mm water pipe too.I done that before and put them up for £70. No one was interested at that price which meant earning about £10 an hour I thought why bother.
Would you mind if I showed my wife this photo? It might work ...... Or not.
Got a "How to" on these, they are really cool. I have done wooden flowers on my lathe but would like to try theseThat's why I've never done it before but I reckon making ten at a time I could do them a bit quicker. Would probably save a bit of time starting with annealed sheet rather than 22mm water pipe too.
View attachment 274602View attachment 274601
Just had a thought, there's probably money doing metal versions of trendy houseplants, people sell cuttings, literally single leaves, for upwards of fifty quid because they're slightly more variegated than the plant usually is!
The clamp has started working lose when in use so the router blade drops down when taking a cut, machinist jack is my temporary work around
I've got one of those little cheapo lifting tables from the bay that I use to support my router. Not only stops it slipping but makes adjustment a doddle.The clamp has started working lose when in use so the router blade drops down when taking a cut, machinist jack is my temporary work around
Cheers for that! I need that in my lifeI've got one of those little cheapo lifting tables from the bay that I use to support my router. Not only stops it slipping but makes adjustment a doddle.
Mini Lifting Table
I have a job now and again removing a pump from the bottom of a machine for inspection / maintenance. Its a right pig getting it down on your own and there's no real room. At over £7k I really dont want to drop it..... Thank you
