MattF
- South Yorkshire
Per side, or total?It is, of course, only a curling bar, it'll probably never see 40kg in normal use but I had to have a play.
I meant total but that might have been a bit of a modest guess, definitely nowhere near 40 a side though!Per side, or total?
The place my pal occasionally worked in as a family helper had concrete casting rings as a single strip welded up so the top edge was 3 mm smaller than the bottom edge they ground & polished up to give an almost invisible joint . Then tack welded to a base plate at the smallest diameter . They had dozens of them for making round cast concrete slabs for lawn paths . Being in tray form they were filled via a chute of slightly damp fine mix whilst on a vibrating table to give a lovely smooth face . They also fibreglass inserts for the rings they'd made so it looked like the end of a log n the cast face .Quick job for a builder today, a couple of 400 dia concrete moulds, just 3mm mild steel tigged together
You got your money's worth out of that 9" wheel didn't you?Not made today but testing today. 9” and 5” grinder rack. May play around with a few dimensions to make it a bit more compact.
no disc/consumable tabs on this one.
View attachment 272920 View attachment 272921 View attachment 272922
Why not make them as " Y" 's in solid rod so every one of them can take a big blade & weld on a bent "U " or a cross piece ( bolts to the wall ? ) near the base to take the cable coils.Not made today but testing today. 9” and 5” grinder rack. May play around with a few dimensions to make it a bit more compact.
That would take me far longer and look Pretty pants I think. These have the logo, cable hook, consumables tabs. I can cut one of these, clean it up and fold it in about 30 minutes.Why not make them as " Y" 's in solid rod so every one of them can take a big blade & weld on a bent "U " or a cross piece ( bolts to the wall ? ) near the base to take the cable coils.
Brad what's your secret to keep your grinders clean ?Not made today but testing today. 9” and 5” grinder rack. May play around with a few dimensions to make it a bit more compact.
No probs, but I see what you mean. Nice and simple always bestNo checked there and Iv none of the back of any . It’s basically just 2 40mm strips across the top and bottom and screwed together to make one piece . Reason for doing it is makes after care a lot easier for the customers they can pop out the panel to repaint and varnish
What's the 24V/240V set up for? Nice, neat workMade a bench grinder stand thé other day, boss said, how long will it take? So painting it wasn't an option, too busy at thé moment.
Then continued with installing 2x24 volt pure sine inverters. Thé 24 volt sides about finished, got to go over thé 240 volt systèm, it's not quite how it should bé.
View attachment 272840 View attachment 272841 View attachment 272842
Get in there mate before she changes her mind! You'll regret it for the rest of your life if you don't try!Actually yesterday .
The day before I've picked up a maintenance kit for Milwaukee PLH32QEX , I've had it already completely disassembled ,so I've took only 2 hours to clean it all , replaces all the rubber parts ,antivibs, orings , gasket, bearing grommet ,carbon brushes , applied new fresh grease (two different types for different parts which needs lubrication )
New stretching screws .
New quick change flange (fixtec part )
Cleaned it up using brake cleaner and a rag.
80 euros
38 parts
35 euros profit.
Then something happened in the evening.
After the second letter to her I've probably hit the target .
I've had to move my car to another parking.
While parking I've seen her trying to find the courage to go into my alley ,I was little bit far , she started watching around and go away.
I didn't manage to get closer to talk her ,she was already pretty far and since she's really shy ,I didn't want to force the things.
But I heard in my mind "hurry boy , she's waiting there for you"
I'll knock on her door one of those days
Next time just raise your hand and wave at her, with your best smile. Just letting her know you noticed her can break the iceWhile parking I've seen her trying to find the courage to go into my alley ,I was little bit far , she started watching around and go away.
that'll put a smile on your faceThen something happened in the evening.
One runs a diesel conventional household central heating system.What's the 24V/240V set up for? Nice, neat work![]()
I'll try .that'll put a smile on your faceMake sure she sees it
I'll try .
However it will go wouldn't be wasted time
