Dieselman 63
Forklift Certified
- Wellington, New Zealand
Can you weld up brass?
I’ll get some spacers made up and proper bolts etc, just a mock-up for now but it works really nicely.
The handle would be better with a bracket fabricated to strengthen/support the outer end of the pivot pin?
No, you cannot weld it. Soft (plumber's) solder will be fine for that. Cleanliness is you friend when soldering. Sweat a brass washer either internally (thin one) or externally (thicker, depends on bolt length*) over the cracked area to spread the clamping load.
Anneal it before attempting to bash it back into a flatter state.
Consider making a hollow brass spacer that goes between the bottom of the carb and the top of the underside of the float bowl. Fiber washer between spacer and bowl on the inside. Then it is not possible to overtighten it.
* you can thin down the underside of the bolt head on a lathe if you need a little more length using the same bolt.
Someone else should chime in here, but I think there are trailers that you can connect to the PTO so their axle is also driven for help in muddy conditions (hazy thought that this was possible on 101 Landrover).
There is an old film set in the desert during the war. They were stuck on a sand dune and used the starting handle with the lorry in gear to gradually wind themselves out of trouble.
The Dutch army truck has a PTO driven trailer. (I met a Dutch couple touring SW Scotland in one a few yrs back, towing a PTO trailer. Big v8 in it, he said it did 8mpg, without the PTO trailer hooked up)
I bet. The correct name is Steyr Puch Pinzgauer. There’s a newer model for sale on eBay at the moBut was that 8mpg across anything you want?![]()
"Ice Cold In Alex", excellent film.There is an old film set in the desert during the war. They were stuck on a sand dune and used the starting handle with the lorry in gear to gradually wind themselves out of trouble.
Historical accuracy is a bit off, there’s a series 1 Landy in the background in one shot..."Ice Cold In Alex", excellent film.
Good trucks, pinzgauers. Like a more modern forward control landyI bet. The correct name is Steyr Puch Pinzgauer. There’s a newer model for sale on eBay at the mo
Steyr Puch Pinzgauer 710k 4x4 | eBay
Find many great new & used options and get the best deals for Steyr Puch Pinzgauer 710k 4x4 at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
And you noticed that looking past Sylvia Symms?Historical accuracy is a bit off, there’s a series 1 Landy in the background in one shot...
I’m a Landy man through and throughAnd you noticed that looking past Sylvia Symms?
