Be careful with the gaskets, given the age it may well be asbestos
That’s a very good point, I’ll be make sure to wear a mask when I scrape it off, thanks for the heads up better to be safe than sorry
I doubt that that was how it came from the factory. It looks like rust pitting from what I can see.
Better off soaking it in WD40, stops the fibres getting airborne in the first place.That’s a very good point, I’ll be make sure to wear a mask when I scrape it off, thanks for the heads up better to be safe than sorry
Deep metallic BlueMost definitely no point doing all that to make it looks pants still, just not sure what colours to go, any suggestion?? I’m currently deciding weather I do the motor an tank aswell now or just the compressor for now.
got 0.5mm high temp gasket material coming next week Unlike air compressors ,fridge compressors are not sealed crankcase the intake gas enters the crankcase so an amount of oil will pass through the compressor they normally have an oil separator in the discharge line.continuted
SO like I said not 100% on how there was so much oil in the outlet valve unless its just from years and year of operation, like i said i dunno how ling this has been like it.
Yeah I finally figured that one out after I saw the hole from the inlet into the crank case, haven’t looked in the tank yet to see if there is oil in there too, for the amount of time I’ll be using it, the compressor will at the most run for a hour a week, if I find myself using it more I’ll think about adding a oil separator in of some sort just to incase the oil does get into my airline. Would you know roughly what type of oil is best for these fridge compressors?Unlike air compressors ,fridge compressors are not sealed crankcase the intake gas enters the crankcase so an amount of oil will pass through the compressor they normally have an oil separator in the discharge line.
We always used shell clavus 68 this was in the old days of r22 refrigerantYeah I finally figured that one out after I saw the hole from the inlet into the crank case, haven’t looked in the tank yet to see if there is oil in there too, for the amount of time I’ll be using it, the compressor will at the most run for a hour a week, if I find myself using it more I’ll think about adding a oil separator in of some sort just to incase the oil does get into my airline. Would you know roughly what type of oil is best for these fridge compressors?
Thank you bornfreeWe always used shell clavus 68 this was in the old days of r22 refrigerant
so I had to use the old manual way and cut them out by hand, I reprinted the CAD drawings I did and got to work, having borrowed a hole punch kit from a college which was a big help and a pair of scissor's I made all the gaskets, they came out a lot better than I thought they would and as I cut the paper ones out once before I knew they would fit. I also decided to clean up and paint the fixings for the compressor, now this was probably not the best method of paint but worked, I used cold galv spray for 2 coats and it was a matt grey color so I then did 2 coats of clear coat and they darkened up and a gloss finish so I was happy.
hit me up lol
so yeah wasn't too impressed but you get what you pay for, so I ended up straighten it out and get it to look like it should and of course I didn't like the orange so you guessed it........its now red
good news was the oil bearings and the spring washers (for taking backlash out of end float, don't know proper name) was all good
so ill be removing all of that and giving it a good jet wash out and get the worst bits out, not sure if there is anything I can line the tank with afterwards, its from 1960 so its very thick walled so not worried about rusting too much but I am planning on once its cleaned and stripped of paint to hydro test the test just as a piece of mind really.Thank you @3000alloy much appreciatedWow, really impressive. Well done so far.
That rebuild is a credit to you.Thank you @3000alloy much appreciated
