Yup. Last time I used it, which was 2 months ago and I couldn't be bothered trying to put it back on as I'm putting everything through the rapidor now.anyone have issues with the blade coming off?
I do need to fix it though so any tips welcome!
havent really looked yet, really bugging me. When i find a solution ill post it
Mine seems to be working fine out of the box.
The vice could be better. It has a tendency to push the work piece up when you lock it.
The new blade I put in might have a missing tooth as it jumps at a certain point.
I made a handful of cuts so I don't have much to go by, but initial impression is it's ok.
Lol I'm talking about the aldi one![]()
In desperation I ended up cutting a slice out of an old inner tube and fitting it over the drive roller
The new blade I put in might have a missing tooth as it jumaps at a certain point.
Tension
The tensioner was bottoming out but the blade was still loose so sort this i filed all 3 slots longer, the now has a distinctive ping when flicked and sits against the stops in the throat when running
