Adam Marshall
- Nottinghamshire England
what are the advantages of using this wire over solid wire? Is this a copper coated wire?
In practice, the G4Si1 weld will have a higher strength than the G3Si1.G3Si and G4Si have the same yield strength of 460 when welding with mixed gas.
the impact value of G3Si is -40 degrees and the impact value of G4Si is -50 degrees this is the only difference from both wires
Lincoln classify Supramig Ultra as G50 5 M 4Si1.....higher than Supramig G46 4 M 3Si1Yes, that is correct, but it is about the minimum yield strength that the manufacturer guarantees.
I've read that some Lincoln wires are manufactured in the UK; out of curiosity do you know which ones @TechnicAl ..?
Esab classify their G4Si1 as G46 etc
Yes....thats the same as the Esab classificationLook at UltraMag SG3
