8ob
- Nescient in the vale
Mk1 is/was a box of tricks I knocked up many years ago to help in wiring/diagnosing trailer/trailer board electrics without the need for a vehicle to plug into.It could also be used to check the tow bar electrics. Downside is it needed a battery to plug into, it wasn’t water proof and the thirteen pin plug has since emerged.
The plan
Condense the whole lot including a battery pack,charger, remote fob, override switches ,led check lamps, both 7//13 pin trailer sockets and include the aux feeds.
Tried a 50 cal ammo box but it was all a bit too tight so went for the fat cal ammo box with a rubber seal on the lid.
Work in progress, got the nine/thirteen pin plugs wired up and bolted in, fitted the check leds for the trailer lamps, need to find a place for the aux warning lamps.
The plan
) and would forget to turn off the camera.
At 7am in the morning in the pitch dark and with three guys waiting (at my expense) to go to work I need to be able to check both truck and trailer as quick as I can, it’s not their problem they have ripped the wires off the day before and failed to mention it , it’s mine. I haven’t found anything better than the Mk1 so I am just refining the concept and bringing it up to date so it’s completely stand alone. A few mates have copied mine and they all swear by them, also means I can take trailer boards and trailers into my workshop and Wire/test/ repair them without needing a vehicle in there.
