It has been a bit warmer here (London) today but it is still cold and damp, there is no way I would be spraying anything without additional heating, can't think the Midlands are much better. I would be getting the heaters out if I had to do any painting this weather.As above. Trying to cover some top struts and after 24 hours the primer has not hardened.
No...Did you apply heat?
That would help, to warm up the panels before spraying and after it is only primer so a bit of dust is not going to hurt.
Just tried a heat gun. Lol low setting and it makes it crack.That would help, to warm up the panels before spraying and after it is only primer so a bit of dust is not going to hurt.
You should have seen me trying to get VHT crackle black to pucker, ended up getting the heat gun on it (low setting).![]()
See that was what I was going for with the VHT crackle, I just hope you did not do that in the 30 seconds it took you to reply, a: I would be impressed with your speed of posting but b: feeling very sorry for putting bad ideas out there on the WWWJust tried a heat gun. Lol low setting and it makes it crack.
I was already doing it before you replied to see what would happen.See that was what I was going for with the VHT crackle, I just hope you did not do that in the 30 seconds it took you to reply, a: I would be impressed with your speed of posting but b: feeling very sorry for putting bad ideas out there on the WWW
and too coldLooks like you put too much on too soon
