DennisCA
- Finland
The diameter of the pipe should be in relation to the flow ("power") of your blower. Use as little hose as possible, they really kill efficiency.
EDIT: I see this is a smaller vacuum type, not a full size one, they are made to work with the size range of your typical vacuum hoses. You could go a bit higher, I once used mine with a 50mm hose.
, I can’t wait to get mine finished. I’ll be hoovering up so much sqarf and bits when it’s done
