My guess is you won't get cheap tommorow..Thanks for the advice, ideally I just wanted something cheap that I could pick up tomorrow but if they aren't ideal then I'll go for the PSU
- should the anode corrode away quickly? mine are attracting plenty of crud (magnetite?) but not showing any signs of disappearing.
does the process have any detrimental effect on aluminium? I'm using plastic container just now but wondered what would happen if that was swapped for aluminium
You need to clean your waste metal regularly otherwise the cleaning process slows down. When you clean it you will see where the metal has been eaten away.
I have been cleaning the anodes (waste metal) and that's why I'm seeing that they aren't disappearing at any noticeable rate. they are quite big in fairness but thought I'd see some etching
