gordon stephenson
- Skelton in Cleveland U.K.
I have seen even broken Taper locks used at a push, and lasted in service without any issues.
email said:Get 15% off to complete your order
We noticed you have left a few items in your basket and we'd like to see if there was anything we could do to help.
We'd like to offer you a 15% off coupon, valid for the next 48 hours on any item in our catalogue.
You'll find the coupon at the end of this email.
Welllll... here's a top tip!
I added the pulley and taper to the cart this morning, to find out how much it was going to be, then just left the computer.
Came back this afternoon to an automated email from bearingboys saying:
So I've ordered them. Today's top tip is to make sure you're logged in (so the site has your email address) then leave things in the basket for a few hours.
This worked with Nespresso a year or so back when they gave me £50 off a machine that had been lying in my basket, that I hadn't yet purchased.
How did you pick up the threads in your new pulley?
That's really impressive, and way beyond my abilitiesI machined taper lock bores a number of times, it’s actually rather simple once you’ve done one:
View attachment 260258 View attachment 260259 View attachment 260264 View attachment 260260 View attachment 260261 View attachment 260262
Ebay do it too, only if you watch the item. Basket doesnt work. Often next day theres a message with a 5-25% discount for 48 hours.
Cross & Morse version is a bit cheaper I think. Plain bore only needed in the hub, and plain shaft. No keys. With transmit incredible amounts of torque. Very useful for start/stop indexing operations - no fretting on the keyway or shaft. Have to be fitted correctly, going around and around the set-screws to tighten them properly.When you fit a taper lock be careful with the fit of the key. If it is at all tight in the radial direction the inner bit of the taper lock is stressed over it and will crack as you tighten the Allen screws that hold it all together. Although the key needs to be a good fit in the key way it needs about ten thou ‘headroom’ radially.
I first discovered this when I dismantled my 6 foot field flail for rebuilding but have come across it several times since.
