Oh, I'm not suggesting powering your mower off gunwash!
Just returning it to a clean state.
Distilling it has crossed my mind too but I doubt it's economical, leccy bill would probably outweigh the cost of new solvent.If you let it sit for a few weeks does it clear up? I save the white spirit I was brushes in, if I don't touch it for a while nearly all the paint drops out and I can carefully pour off the mostly clear liquid to use again. I've been meaning to get some centrifuge tubes and see if ten minutes at 130x gravity clears it up any further.
What sort of volume do you get through?
I haven't, but if I think of it when I'm home at Christmas I'll try it.Have you tried dripping some of your "cleaned" solvent on a mirror? I'd be surprised if there is not some residue.
Which may, or may not be acceptable, depending on the job, of course.
Leave it to clear transfer the clear liquid into a new container and use it to clean oil off things
Lidl, that can't be cellulose thenIf it's anything like the cheap paint thinner I get from Lidl it might turn oil into a sticky stringy mess.
NiceI will of course ignore the environmentalists comments
that baufix stuff?If it's anything like the cheap paint thinner I get from Lidl it might turn oil into a sticky stringy mess.
that baufix stuff?[/QUOT
Yes.
and ends up knacking your slabs with a crappy colourI take mine to a local garage and add it to the waste oil he uses to heat the garage.
Otherwise, yes, an excellent weedkiller especially in the gaps between slabs
