Yep, did a 4 hour video conference training course with the company last week.The grille at the end is holding the two halves together. That needs to be prised off.
Mine is like this - held by the round bit at the front. Not very secure tbh so I put some cable ties around mine.
Been running 50hrs a week for about 16 months now no trouble at all.
Using kero.
They are 4kw though not 8 as promised.
The company is based in Russia, and it says made in Russia on all the labels.@barking mat Can I ask how you know it's from Russia?
i assume by russian you mean the planair/autoterm ones?
they're a little better built than the chinese ones, and generally accepted to be the best quality heater that isn't Webasto and eberspacher.
having said that i have a webasto and 2 chinese heaters. one "8kw"(not really, they're all 5kw, whether they say they're 3,5 or 8) chinese all in one. it heats my garage and is 100% reliable over 2 winters now. fuel tank could be a bit bigger though. second is a 5kw in my lorry, does a good job, not had much use but seems to work well. i found it needs a non return valve near the tank to stop it draining back when not used for months, and the fuel tank cap seal swelled so the tank got vacuum locked. both easy fixes. the webasto is in dads horsebox, does the job, only issue was with the pump failing as it would mounted outside with no protection, and the doggy 24v supply that caused it to go into fault every time it tried to start. fixed with a decent fuse box not the low quality crappy one that was already there.
my point is, i don't have any issues with the chinese ones, in fact I've had more issues with the webasto, although to be fair, its older....
Yep certainly is.Is it branded Planar?
My Chinese one also has a broken clip and it works fine, however I might have tripped over something while installing it in the garage and dropped it...![]()
@barking mat I believe you
Webasto & Eberspacher have definitely lost a massive market share to the chinese. I nearly bought one the other day for £85 brand new
They're that cheap you can afford them to be disposable
i can do better than that...£85 quid !!!!
Id like a link to that please.
That's unbelievably cheap. Second time I've typed that in two days.
Thanks again, I'll join some groups after dinner, much appreciated. Mathttps://www.facebook.com/groups/DieselHeaterSafety/?multi_permalinks=358315088764122
https://www.facebook.com/groups/265862240781579/?multi_permalinks=676042029763596
https://www.facebook.com/groups/146837062640024/
https://www.facebook.com/groups/358361758340771/
https://www.facebook.com/groups/388958075385659/
https://www.facebook.com/groups/283466485963713/
all these groups are your friends.
Ahh, thingmyibobs...think you have to buy a thingymibob so it runs off 12volt I think 15.00 off eBay only cheap
