Thought I might create a little thread here as I'm motivated (at the moment) to try and get on with this and there's a fair bit of experience and expertise here that I would like to draw on.
Following on from my post in "Things I have made today" I have welded those rear tubes that I had tacked on and completed the rear shock mount plates with stiffeners. Tonight I cut out the lower tube to give clearance for the diff nose and prop. The floor panels that I cut years ago have been dragged out and this brings me to my first question.
I want to avoid the dreaded pinging floor syndrome. The floor is specced at 1.2mm steel. I have a bead roller to put some ribs in so I am wondering about the best design. I have seen an X shape used once in the past, is this a good idea? The floor panels are longer than they are wide so I assume they would bend more front to back along the longest axis so I thought ribs running side to side would interrupt this. I had a look a mini replacement floors but I notice they have ribs running front to back along the long axis instead so maybe my thinking is wrong.
How many ribs would be necessary? I think too many might distort or alter the panel dimensions too much. If I get it all wrong it won't be the end of the world to start the floors again. I think I'm on a hiding to nothing as I probably should have put the ribs in first and then cut the panel to fit after. Some pics.
Random image of Mini replacement floor. Something to emulate?
