Matchless
I started with nothing, still have most of it left
- Essex UK
I have repaired the oil union hole in Matchless single engines by techno welding in a brass union fitting, techno / Lumi weld sticks to brass but not to steel, you can form a crude thread by techno welding around a steel stud, when it cools and you remove the stud you have a thread! I have also repaired a casting blow hole deep inside a BMW cylinder head inlet port that would have been impossible using tig, mig or much else, it needed heating in a big oven to get up to temp. and careful slow cooling but it worked, main problem with even small casting repairs is getting enough heat into the piece.
Must buy some more.
